System Starts before Power Switch is Pushed--Solution Posted
hmsrolst
5,269
I'm building a system with a new case and PSU. When I flip the the surge protector switch to on, the system boots up. When I close Windows, the system shuts down, and if I leave the surge protector on, it will turn on when I push the system power button. I've used two different Intel boards (which I'm not very familiar with) of two different vintages (ZX and 815EP) with the same result. Is the PSU (which doesn't have a kill switch) defective, e.g., letting too much juice through, is the system power switch defective (it works fine except when the surge protector is initially turned on), is this an issue with Intel boards, or is it something else?
bacillus
14,517
check in bios to see if "ac pwr loss restart" or something similiar has been set to enable.
normal option is disabled!
Amused
57,444
19,892
Actually, in every system I've built in the last year (all Asus mobos) that BIOS option was enabled by default. I hate that.
hmsrolst
5,269
Thanks, bacillus. I guess it's enabled by default on Intel mobos. I've build dozens of machines, mostly with Asus and Abit boards, and never encountered this.
