System spontaneously rebooting, helb
Crispy86
System:
AMD Athlon XP1700+
Gigabyte 7VRXP Mobo (Rev 1.1)
1x512DDR-2700 RAM
Geforce 3 ti500
Creative Soundblaster Live! DE 5.1
40gb Maxtor HD
80gb Maxtor HD
350W Enermax PSU
Win XPHE SP1
I?ve been having this problem for quite a while now and I just can?t seem to fix it. If I look at the event viewer the error is:
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 30/03/2003
Time: 4:24:29 PM
User: N/A
Computer: TIM
Description:
Error code 10000050, parameter1 c1c254ec, parameter2 00000000, parameter3 bfb742f7, parameter4 00000000.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 31 30 30 30 30 30 35 1000005
0020: 30 20 20 50 61 72 61 6d 0 Param
0028: 65 74 65 72 73 20 63 31 eters c1
0030: 63 32 35 34 65 63 2c 20 c254ec,
0038: 30 30 30 30 30 30 30 30 00000000
0040: 2c 20 62 66 62 37 34 32 , bfb742
0048: 66 37 2c 20 30 30 30 30 f7, 0000
0050: 30 30 30 30 0000
The weird thing is that it is so random, sometimes it?ll be five days until the PC reboots, mostly when I?m playing a game (c&c generals) and sometimes it happens like 4 times, 5 minutes apart when I'm just surfing the net.
I did the usual stuff ? checked temps, changed drivers for vid card, updated via4in1?s. Didn't fix it. However, then I tested the memory, memtest v3.0, and it found 169 errors after completing 2 passes. So could this be the cause?? 169 errors doesn?t look to good? Any other suggestions?
Thanks in advance.
Crispy
steelnewfie
469
Also keep an eye on your temps.... Heat could cause it... Reseat the CPU/HSF if mem swap doesn't help.
Nomans
78
Crispy86, most likely you got a bad 512MB DDR PC2700 memory stick. As far as I know, only 2 components of the system could trigger this kind of random system reboot: bad memory and bad mobo. Try replace that memory stick and see whether it'll go away. It' possible that PC games, which usually put a huge load on every hardware component of the system except HDD when they run, most of all the game will try to allocate as much memory it could get from Windows for all kind of fancy graphics and textures, and thus come to utilize portions of memory where regular applications don't necessarily go after.
DanTMWTMP
15,908
19
Another vote for the RAM change...
I thought about maybe it's a bad PSU, but you have a good PSU and shouldn't worry about it, unless you have a manufacture defect...but since you get an error before the reboot, you don't have to worry about the PSU being the problem.
Sometimes works, sometimes doesn't....i've had a ton of problems w/ soundblaster anything.....they have horrible driver support. I had BSOD's because of my TV card and soundblaster conflicting w/ each other.
Looking at your system specs, those are 2 potential, but HIGHLY UNLIKELY problems....maybe it contributes to the problem due to poor ram...
YES CHANGE UR RAM...then if it happens, look into those two other potentials...
good rucks! :)
