ok.. here it comes..
i bought a brand new built by ati radeon 9500 pro.. now here's the thing..
i put in the card, formatted my hdd, did a frsh install of xp, put on dx9, then installed the catalyst 3.2 drivers..
now when i start up windows everything is fine.. the refresh rate is good, there are no conflicts with anything.. but when i start up a 3d application my system (or the card - i honestly do not know!) freezes and occasionally restarts. like for example fifa 2003, freelancer or 3dmark 2001SE. i have the latest agp drivers from sis too. it gets in the game but when the loading proccess is over and the real 3d needs to start, thats when it happens.
now here's the interesting part:
i went to my friend who has a pentium 3 system and checked the card there. installed the drivers on the existing windows he had with dx9.
after the restart no game worked because in windows it said that the agp transfer rate was set on 'off' instead of the regular 2x,4x or 8x.
ok, that was strange but i continued trying to set the card right. i removed all the other programs installed with the driver like hydravision and all those. restarted, still nothing, then i went into the device manager and clicked 'update driver' and updated to the same driver i installed earlier.. restarted.. and vwalla.. all the games started.. freelancer.. c&c generals.. everything worked. no restarts.. no freezes.. no nothing. so i was really happy to see that and ran straight home to try the same procedure on my system. did exacly what i did on my friend's system but still no luck! i get the same crashes when i open up games and 3d apps in general.
what could possibly be wrong as i am sure that if the card works on a pentium 3 system it should have no problems running on a pentium 4 system (which i have).
any help would be gladly appreciated!
my system:
pentium 4 2.0 ghz
motherboard: MSI-6547 supports agp 4x - not 8x
256 mb ddr 333
sis 645 ultra-c chipset
win xp pro
SB audigy 2
80 gb seagate 7200 rpm
my system:
pentium 4 2.0 ghz
256 mb ddr 333
win xp pro
SB audigy 2
