System Restore and Memory questions
Mike1949
27
Videocard: BFG 6800 GT OC
Processor: Athlon XP 2600+ 2.2 Ghz
Mainboard: Shuttle AN35/Ultra v1.1
Memory: 2 X 512 PQI PC3200 Turbo Ram
Soundcard: Onboard / Cambridge Soundworks sub-
PSU: Antec TruPower 430w
I recently used system restore to go back 1 month to fix a malware problem.
It seemed to work.
Afterwords I saw a message in my event viewer however that said that some of my memory
is being used by something in a another or substitute registry and that it would be released if needed.
Also my comp is now listed in Event Viewer as Desktop 2
If I look at my task manager right now under Performance /Physical Memory/ it tells me that I have
a Total of 1048052
Available 735948
System Cache 197488
Is this normal?
My comp seems to work fine and I dont want to worry about nothing,Im just curious
I have 20 start-up items loading (just the bare minimum) and as I write this only this web site and the task manager open.
Also 1 more question: If I use System Restore to roll back to fix a problem and it doesnt fix the problem, can I then bring
it back to the present day without screwing anything up?
Roguestar
6,045
20 startup items is your bare minimum?!
Start->Run: msconfig
I don't think you can undo system restore; ie: come back to present day, check the MS knowledge Base.
Captante
30,354
10,882
You can use system-restore to undo the last restore operation you performed, but I wouldn't bother because its likely it will only compound the problems your having. The issue is that system restore won't remove most virus's or malware & in fact that type of application will often hide withing restore data & re-infect your system wether you use it or not.
Do you have any antivirus or anti-spyware programs installed on your PC?
Mike1949
27
Just Kaspersky Anti-Virus and Spybot.
Ive tried turning off Kaspersky and the SpyBot was installed after the problem
started.
Ive started it in safe mode and it spikes.
I have used TweakNow registry cleaner and eliminated at least 60 or 70 bogus registry entries and it still spikes.
I have tried unplugging my modem, checking any and all task schedulars
or anything that might turn itself off or on and several Navajo prayers and
it still spikes.
I do have it overclock from 1.9 to 2.2 and the V-core from 1.6(auto) to 1.75
I dont remember seeing this after I O.Cd.
Actually my comp runs great except for the spike.
Its just driving me batty trying to get rid of it.
Captante
30,354
10,882
It does sound like you have some kind of malware infection on your PC & its very likely you'll end up being forced to format & re-install, however I suggest you first disable system restore & then try a couple different online virus scanners to see if one of them can snag it ... I've had the best results with Trend Micro ... while there you should also download & run Hijack This & take a look at everything running in your PC.
Heres a couple more:
Bitdefender online scan
F-Secure online scan
Slikkster
3,141
Download and run "Hijackthis", which will list all the processes running on the pc, as well as browser helper objects (possible spyware) and other elements that might be causing problems:
http://www.majorgeeks.com/downloadget.p...0&evp=4122712c2af084c815e5fd4f2b249d83
Choose the System Scan and Logfile option. This will scan the system, and then pop up a text file in notepad. Copy/paste the results of your hijackthis scan here, and we'll take a look.
Mike1949
27
OK heres my HijackThis SystemScan and Logfile.
I really appreciate this guys
Logfile of Trend Micro HijackThis v2.0.0 (BETA)
Scan saved at 6:56:51 PM, on 5/1/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Logitech\MouseWare\system\em_exec.exe
C:\Documents and Settings\Primary\Desktop\HiJackThis_v2.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar =
http://red.clientapps.yahoo.com/customize/ycomp/defaults/sb/*http://www.yahoo.com/search/ie.html
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = about:blank
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = about:blank
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = about:blank
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
R1 - HKCU\Software\Microsoft\Internet Explorer\Search,SearchAssistant = about:blank
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = about:blank
R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://red.clientapps.yahoo.com/customize/ycomp/defaults/su/*http://www.yahoo.com
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = sas.*.attbi.com
R3 - Default URLSearchHook is missing
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: TTB000000 - {62960D20-6D0D-1AB4-4BF1-95B0B5B8783A} - C:\WINDOWS\COUPON~1.DLL
O2 - BHO: (no name) - {6F8F6D52-E43E-F6A7-3704-C2291FA9AAF6} - (no file)
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O2 - BHO: (no name) - {f7d40011-29bb-43eb-9c97-875ce89e9e36} - (no file)
O3 - Toolbar: CouponBar - {5BED3930-2E9E-76D8-BACC-80DF2188D455} - C:\WINDOWS\CouponBarIE.dll
O4 - HKLM\..\Run: [Logitech Utility] Logi_MwX.Exe
O4 - HKLM\..\Run: [AVP] "C:\Program Files\Kaspersky Lab\Kaspersky Anti-Virus 6.0\avp.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Default user')
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra button: Web Anti-Virus statistics - {1F460357-8A94-4D71-9CA3-AA4ACF32ED8E} - C:\Program Files\Kaspersky Lab\Kaspersky Anti-Virus
6.0\scieplugin.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\Program Files\AIM\aim.exe
O9 - Extra button: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe (file missing)
O9 - Extra 'Tools' menuitem: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe (file missing)
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O12 - Plugin for .mpeg: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin3.dll
O16 - DPF: {39B0684F-D7BF-4743-B050-FDC3F48F7E3B} (FilePlanet Download Control Class) - http://www.fileplanet.com/fpdlmgr/cabs/FPDC_1_0_0_44.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) -
http://v5.windowsupdate.microsoft.com/v...86/client/wuweb_site.cab?1096690073375
O16 - DPF: {D1E7CBDA-E60E-4970-A01C-37301EF7BF98} (Measurement Services Client v.3.11) - http://gameadvisor.futuremark.com/global/msc311.cab
O16 - DPF: {D4323BF2-006A-4440-A2F5-27E3E7AB25F8} (Virtools WebPlayer Class) -
http://a532.g.akamai.net/f/532/6712/5m/...m/6712/player/install3.5/installer.exe
O16 - DPF: {D719897A-B07A-4C0C-AEA9-9B663A28DFCB} (iTunesDetector Class) - http://ax.phobos.apple.com.edgesuite.net/detection/ITDetector.cab
O20 - AppInit_DLLs:
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\System32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\System32\browseui.dll
O23 - Service: Kaspersky Anti-Virus 6.0 (AVP) - Kaspersky Lab - C:\Program Files\Kaspersky Lab\Kaspersky Anti-Virus 6.0\avp.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel
32\IDriverT.exe
O23 - Service: iPod Service - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: Sandra Service (SandraTheSrv) - SiSoftware - C:\Program Files\SiSoftware\SiSoftware Sandra Lite 2007\RpcSandraSrv.exe
O24 - Desktop Component 0: (no name) - http://us.news2.yimg.com/us.yimg.com/p/...4724.photo00.photo.default-378x279.jpg
O24 - Desktop Component 1: (no name) - http://us.news1.yimg.com/us.yimg.com/p/uc/20050125/sga050125.gif
O24 - Desktop Component 10: (no name) -
http://us.news3.yimg.com/img.news.yahoo...20050429%2Fcapt.mojf10804292314.sand_p
ainting_mojf108.jpg?v=1
O24 - Desktop Component 11: (no name) -
http://us.news3.yimg.com/img.news.yahoo...20050503%2Fcapt.bag12305032334.iraq__b
ag123.jpg?v=1
O24 - Desktop Component 12: (no name) - http://us.news1.yimg.com/us.yimg.com/p/uc/20050525/sga050525.gif
O24 - Desktop Component 13: (no name) -
http://us.news3.yimg.com/us.i2.yimg.com...380&y=276&sig=YuXOuB64DsL1yV_u9u027w--
O24 - Desktop Component 14: (no name) - http://us.news1.yimg.com/us.yimg.com/p/uc/20050527/sga050527.gif
O24 - Desktop Component 15: (no name) - http://us.news3.yimg.com/us.i2.yimg.com...380&y=274&sig=7TCfRbN62hzXy8M0dlNaWw--
O24 - Desktop Component 16: (no name) - http://news.nationalgeographic.com/news/2005/08/images/050831_new_orleans.jpg
O24 - Desktop Component 17: (no name) -
http://us.news3.yimg.com/us.i2.yimg.com...380&y=202&sig=qwiHLEhyFHnwhYgKE1Gxrg--
O24 - Desktop Component 18: (no name) - http://us.news3.yimg.com/us.i2.yimg.com...262&y=345&sig=pO6wO6yHLyDQpbPEjcCK_A--
O24 - Desktop Component 19: (no name) -
http://us.news3.yimg.com/us.i2.yimg.com...238&y=345&sig=oIyu_DzXSreABiv1A3ZkNQ--
O24 - Desktop Component 2: (no name) - http://us.news1.yimg.com/us.yimg.com/p/uc/20050211/sga050211.gif
O24 - Desktop Component 20: (no name) -
http://us.news3.yimg.com/us.i2.yimg.com...259&y=345&sig=RHn0_Mjbi9m45m8RIUk1oQ--
O24 - Desktop Component 21: (no name) -
http://us.f527.mail.yahoo.com/ym/us/Sho...5&bodyPart=1.2&YY=85932&order=down&sor
t=date&pos=0&view=a&head=b&Idx=1
O24 - Desktop Component 22: (no name) -
http://us.f527.mail.yahoo.com/ym/us/Sho...136&bodyPart=6&YY=72986&y5beta=yes&ord
er=down&sort=date&pos=0&Idx=2
O24 - Desktop Component 23: (no name) -
http://us.f527.mail.yahoo.com/ym/us/Sho...136&bodyPart=6&YY=33940&y5beta=yes&ord
er=down&sort=date&pos=0&view=a&head=b&Idx=2
O24 - Desktop Component 24: (no name) -
http://us.f527.mail.yahoo.com/ym/us/Sho...136&bodyPart=6&YY=48591&order=down&sor
t=date&pos=0&Idx=3
O24 - Desktop Component 25: (no name) -
http://us.f527.mail.yahoo.com/ym/us/Sho...136&bodyPart=6&YY=17669&y5beta=yes&ord
er=down&sort=date&pos=0&view=a&head=b&Idx=5
O24 - Desktop Component 26: (no name) -
http://us.f527.mail.yahoo.com/ym/us/Sho...136&bodyPart=6&YY=36891&order=down&sor
t=date&pos=0&view=a&head=b&Idx=10
O24 - Desktop Component 27: (no name) -
http://us.f527.mail.yahoo.com/ym/us/Sho...136&bodyPart=6&YY=1379&order=down&sort
=date&pos=0&Idx=6
O24 - Desktop Component 28: (no name) -
http://d.yimg.com/img.news.yahoo.com/ut...2Fphoto%2Fmovie_pix%2Fmgm%2Fthe_crocod
ile_hunter__collision_course%2F_group_photos%2Fsteve_irwin2.jpg?v=2
O24 - Desktop Component 29: (no name) -
ile_hunter__collision_course%2Fsteve_irwin%2Fcroc2.jpg?v=2
O24 - Desktop Component 3: (no name) - http://us.news2.yimg.com/us.yimg.com/p/nm/20050205/mdf848088.jpg
O24 - Desktop Component 30: (no name) -
ile_hunter__collision_course%2F_group_photos%2Fsteve_irwin5.jpg?v=2
O24 - Desktop Component 31: (no name) -
ile_hunter__collision_course%2Fsteve_irwin%2Fcroc5.jpg?v=2
O24 - Desktop Component 32: (no name) -
ile_hunter__collision_course%2F_group_photos%2Fsteve_irwin6.jpg?v=2
O24 - Desktop Component 33: (no name) -
http://d.yimg.com/us.yimg.com/p/ap/2006...237&y=345&sig=F5ymNUF4zOGUaZR3n6jC4w--
O24 - Desktop Component 34: (no name) - http://us.i1.yimg.com/us.yimg.com/i/ww/news/2006/09/05/steve_irwin_lg.jpg
O24 - Desktop Component 35: (no name) - http://d.yimg.com/us.yimg.com/p/rids/20...249&y=345&sig=zQIp5o1g6ZIZ1EUnqIWTvQ--
O24 - Desktop Component 36: (no name) - http://d.yimg.com/us.yimg.com/p/rids/20...244&y=345&sig=T9bPvgf7JbcV4JCsW61gUA--
O24 - Desktop Component 37: (no name) -
http://d.yimg.com/us.yimg.com/p/ap/2006...380&y=251&sig=pMsD.f98iMcUDAobBNaCnQ--
O24 - Desktop Component 38: (no name) -
http://d.yimg.com/us.yimg.com/p/afp/200...380&y=253&sig=lDS.bdIANDk6jndev7mdHg--
O24 - Desktop Component 39: (no name) -
http://d.yimg.com/us.yimg.com/p/nm/2006...380&y=244&sig=0cyE8iMRMX09AnlfKsVn.Q--
O24 - Desktop Component 4: (no name) - http://us.news1.yimg.com/us.yimg.com/p/uc/20050321/scrbc050321.gif
O24 - Desktop Component 40: (no name) - http://d.yimg.com/us.yimg.com/p/rids/20...380&y=251&sig=yklTIlLpVWVfQlmhSnG2RQ--
O24 - Desktop Component 41: (no name) - http://d.yimg.com/us.yimg.com/p/uc/20060926/sga060926.gif
O24 - Desktop Component 42: (no name) - http://d.yimg.com/us.yimg.com/p/uc/20061029/sga061029.gif
O24 - Desktop Component 43: (no name) - http://d.yimg.com/us.yimg.com/p/uc/20061111/sga061111.gif
O24 - Desktop Component 44: (no name) - http://d.yimg.com/us.yimg.com/p/uc/20061118/sga061118.gif
O24 - Desktop Component 45: (no name) - http://d.yimg.com/us.yimg.com/p/uc/20061130/sga061130.gif
O24 - Desktop Component 46: (no name) - http://d.yimg.com/us.yimg.com/p/uc/20061201/sga061201.gif
O24 - Desktop Component 47: (no name) - http://d.yimg.com/us.yimg.com/p/uc/20061204/sga061204.gif
O24 - Desktop Component 48: (no name) - http://d.yimg.com/us.yimg.com/p/uc/20061219/sga061219.gif
O24 - Desktop Component 49: (no name) - http://d.yimg.com/us.yimg.com/p/uc/20070119/sga070119.gif
O24 - Desktop Component 5: (no name) - http://us.news1.yimg.com/us.yimg.com/p/uc/20050418/sga050418.gif
O24 - Desktop Component 50: (no name) - http://d.yimg.com/us.yimg.com/p/rids/20...230&y=345&sig=pfmqpo7p53YRcg8xQSG_EQ--
O24 - Desktop Component 51: (no name) - http://us.news1.yimg.com/us.yimg.com/p/...0812.china_panda_baby_boom_xbej801.jpg
O24 - Desktop Component 52: (no name) - http://us.news1.yimg.com/us.yimg.com/p/...b.xcs15402091500.poland_zoo_xcs154.jpg
O24 - Desktop Component 53: (no name) - http://www.sheldrickwildlifetrust.org/Updates_Files/11420060541-pic1.jpg
O24 - Desktop Component 54: (no name) -
http://d.yimg.com/us.yimg.com/p/ap/2007...235&y=345&sig=wRppYVO9cugY1L989xOwrQ--
O24 - Desktop Component 55: (no name) - http://www.sheldrickwildlifetrust.org/keepers_diary/118200684646-pic1.jpg
O24 - Desktop Component 56: (no name) - http://www.sheldrickwildlifetrust.org/Updates_Files/114200601149-pic1.jpg
O24 - Desktop Component 57: (no name) - http://www.sheldrickwildlifetrust.org/Orphan_Files/1024200675448-pic1.jpg
O24 - Desktop Component 6: (no name) - http://us.news2.yimg.com/us.yimg.com/p/...5251.photo00.photo.default-278x381.jpg
O24 - Desktop Component 7: (no name) -
http://us.news3.yimg.com/img.news.yahoo...20050425%2Fcapt.iacn10104251925.bulldo
g_beauty_contest_iacn101.jpg?v=1
O24 - Desktop Component 8: (no name) - http://us.news1.yimg.com/us.yimg.com/p/uc/20050430/sga050430.gif
O24 - Desktop Component 9: (no name) -
http://us.news3.yimg.com/img.news.yahoo...F20050504%2Fcapt.sge.moz77.04050517054
4.photo00.photo.default-384x248.jpg?v=1
End of file - 15320 bytes
Slikkster
3,141
Originally posted by: Mike1949
I mean when when my comp sits idle there's a 4% cpu usage spike every 3 to 10 seconds
I just noticed this statement again. 4 percent? That's really nothing in cpu terms. I just opened my own task manager. My cpu is registering 2-4 percent every few seconds. There's certainly nothing unusual about that. The computer is constantly polling applications and services, caching, etc., which takes cpu time. Even having task manager open will register a couple of percent every couple of seconds as task manager takes its own readings.
If you really meant "40" percent, that's another story. In that case, I would open task manager and sort by "CPU". Click the CPU column until you see "System Idle Process" at the top of the list. Then, watch these "spikes" you are mentioning and see what process is causing them. Whatever it is will jump to the top of the list momentarily.
Re: your Hijackthis file...it's mostly clean except for the couponbar entries, which I assume you downloaded out of choice. You also have the remnants of a Trojan Downloader in your Hijackthis file. If you look in the "BHO" section, you'll see a couple of entries that say "O2 - BHO: (no name)" and end with "(no file)".
Run Hijackthis again, and put a checkmark in the boxes next to those two entries and click the Fix button on the bottom. That will remove those two from the registry. Reboot and rerun Hijackthis to ensure those two entries are gone.
Mike1949
27
Thank you Slikkster.
I did as you said and the 2 BHO entries are gone.
I just noticed that my Task Manager update speed was set to HIGH.
I set it at NORMAL and now my cpu spikes are 1% every few seconds.
I guess thats well, normal.
The reason I was concerned is that it used to idle at 0% usage
and then I got a the explorer.exe malware curse and when I finally got rid of it I started noticing the 4% spike and figurerd I had'nt got rid of all of it.
Thank You again
