system resource question.
CocaCola5
Why is win2k reporting two different status on my virtual/swap memory. Under System Information in system tools, win2k is reporting I have 1.5G of virtual memory. But in Performance option under Systems, it reports 530mb, which is the correct amount I set aside. I have 400mb on one partition and 130mb on another partition on a second drive.. Its off like 1G, my system 2k sits on a seperate partition, and I wondering if this could be the reason its off. I am still confuse though because I manually removed all swap file from my system 2k partition and in Systems and Performance Option it even shows I have no swap file size in this partition.
