System Recommendation
alexit3
8
I need some suggestions for fast stuff in my 'utility' machine.
Budget is $300-350. I have drives and a case, but need:
-CPU (either intel or amd)
-1GB RAM
-MicroATX mobo w/pci express
-Any video with a DVI port - no gaming, so as cheap as can be - onboard is a plus cause its one less component to buy.
I'm fine with OC'ing but I can't afford a big aftermarket cooler, and everything will be going in a shoebox, so nothing major.
Currently looking at an asus P5L w/ E6300.
alexit3
8
Various uses, definitely going to do some dual-core supported audio editing, but nothing that absolutely needed.
I'd like the system to last - how long is AM2 going to last compared to LGA 775?
Cerb
17,484
33
86
Since it's easy to find onboard DVI, here's some AMD options.
Some mobos to look at:
http://www.newegg.com/Product/Product.asp?Item=N82E16813130066
http://www.newegg.com/Product/Product.asp?Item=N82E16813131072
http://www.newegg.com/Product/Product.asp?Item=N82E16813130065 ***
http://www.newegg.com/Product/Product.asp?Item=N82E16813131014
http://www.newegg.com/Product/Product.asp?Item=N82E16813136016
*** The MSI w/ onboard Quadro (whatever that really entails--anything other than marketing?) I have ordered for a customer. Looks to me a like a nice feature set and decent board layout.
I don't know the meaningful differences between the nVidia chipsets, TBH.
1GB RAM for $80:
http://www.newegg.com/Product/Product.asp?Item=N82E16820145568
DDR and DDR2 are basically at price parity now.
Just choose a board and fit in the best Athlon 64 X2 in your budget. Core 2 gets more expensive because of adding a video card for DVI, even though the performance will be better (in fact, it may be worth the cost of a cheap PCI-e card to go Intel!). I can't say there aren't DVI-out Intel-based boards, but I can't seem to find any.
In general, if you really want the system to last, get a board with 4 DIMM slots, so you can add RAM w/o replacing what you get in it right off. For pretty much any desktop uses, 1GB of RAM is going to be a serious bottleneck well before even the slowest DC CPUs will be.
Lasting socket: IMO, don't trust that either socket is going to last. Get what you think can hold you over and offer reasonable upgrade potential now.
