System rebooting issue
ronein
Need any ideas on how to solve this problem.
Once i restart the system, it goes to load windows and after about 5-10 seconds reboots.
One thing i did which is weird is if i move the mouse continously while loading windows, it wont reboot.
am using AOL virus shield, scanned and is all ok.
using Ad aware and scanned and all good as well.
Spyware blaster finds nothing.
Spybot search and destroy finds nothing as well.
All above programs are updated.
Not overclocking current system of AMD 4800 on a foxconn c51, 2 gigs of corsair, 7800gtx.
Increased the voltages on the RAM and CPU already just as precaution but still the same problem.
Any other bright ideas other than reloading windows?
TIA!
Thanks for the tip but still same thing.
Moved the RAM around, tried 1 stick only and same problem.
Moved the SATA connections on the HDD and same thing as well.
Switched the fan RPM control to the highest and still the same.
I will try to uninstall all non essential software and see what happens.
