System Q
I actualy have no idea, a friend of mine needs this info...
I dont think it is a northwood...
and i think the celeron is clocked to 1.4....
Let me get this straight.....
What is better...
P4 1.8 with 128mb DDR266
Or
Celeron 1.2 (clocked to 1.47) 384mb PC133
The system will run Xp PRO
At last! 🙂
XP loves lots of RAM.
The Celeron will easily outperform the P4 you mentioned since it has 3x the amount of RAM. The P4, while having a fast CPU, will constantly be bogged down from lack of RAM and the CPU won't work to its potential. It'll be using the HD as a swap file all the time.
Originally posted by: ICEVaPa
What is better...
Or
Celeron 1.2 356mb PC133
RUNNING XP ?
Thanks! 😀
Um...if you can afford more memory, go with the p4. If you can't, that p3 based celery should be pretty good.
