System Process using 95-99% of CPU
rky60
1,077
Hot unplugged a printer/scanner combo from Win2K Pro, my bad? Now the system is draggin a$$. Even in safe mode, no love.
Anyone know a fix?
rky60
1,077
The printer was connected to the scanner, then the scanner was connected by a parallel connection. The hardware is gone, so I can't reconnect it. It's draggin so bad it takes like 10 minutes to load Windows, not to mention tryin to do anything once it does, ugly :)
MrChad
13,507
Have you uninstalled the printer/scanner software?
JerkyBoyz0
32
Yea sounds like the printer software is lookin and lookin for the printer. What type of printer also. The HP printers can do some strange things.
VirtualLarry
56,587
10,227
Parallel does NOT support hot-plugging. You may have damaged the port, and now the lines are floating, and triggering a constant interrupt stream in the background, bogging the machine down bigtime. There are some real-mode DOS printer-port diagnostic tools out there, I would make a bootable floppy and try one of them, and see if the port is fried. Otherwise, you can narrow it down to software issue in Windows.
Also, check if STISVC.EXE (I think that's the one - WIA service) is running, and stop it if it's the one hogging the CPU.
