System powers on but no video signal
samuraijake
51
After coming home from college I took my air compressor to my dust-littered case as I do every year. Long story short, I start the system and the system powers on, the drives spin up, but no video signal to the monitor. I swapped video cards (AGP) and still nothing. I disconnected the power and removed the CMOS battery for a few hours, powered on, and no luck.
Intel D865GBF Motherboard
P4 3.0 Ghz on 800 Mhz FSB
512 MB Kingston PC3200 RAM
ATI All-in-Wonder 9600 (Also tested a GeForce4 Ti4200)
Dual-booting XP Pro and Debian
Any ideas would be greatly appreciated.
Bar81
Banned
Mar 25, 2004
1,835
Alright, did you try to pull out all cards/disconnect everything but the video card and hard drive and see if it works? Alternatively, maybe another monitor?
samuraijake
51
I removed all the peripheral cards (sound, modem, ethernet, extra ide controller) and the same results. I normally run dual monitors on the All-in-Wonder; I have tried both, one, the other, and the same on another video card. Same results: everything powers up, no video signal.
Bar81
Banned
Mar 25, 2004
1,835
Does the hard drive start loading? If not, it sounds like your mobo might be dead. When I've gotten dead mobos (most recently an Asus K8V-E Deluxe) it would exhibit the same behavior.
samuraijake
51
I can hear the HDD spinning and the needles seeking. When I try to reproduce the proper keystrokes at LILO to load XP in order to see if XP boots and produces audio, nothing happens. Assuming it is dead, any idea what could have caused the mobo failure?
Bar81
Banned
Mar 25, 2004
1,835
It could be a lot of things. When you were cleaning the compressed air might of dislodged an already weakened solder point or you might have accidentally touched the mobo and been statically charged or something just died and it's a coincidence is all.
