System Overheating?
Lehm
95
I recently put together an Athlon XP 2500+ system with an a7n8x. I applied a proper amount of thermal compound and used a decent heatsink. Problem is that as soon as I turn it on the CPU temp reads 60c and over about a minute goes to 80c and then shuts itself off. I already tried reseating it a few times. I've even underclocked it to 1.0Ghz. Same thing, I have no idea what is wrong. One theory that I have is that the sensor is reporting the wrong temp, I don't really have a way to test that. I'm kind of stuck here, any thoughts?
acole1
1,543
may sound like a dumb question, but are you sure the fan is running on the cooler?
bendixG15
3,483
Remove the heatsink and reapply.
A common mistake is to use too much compound.
You should be able to see that when you remove the HS
Other thing is to touch the "hot" heatsink.
Other thing is to watch the CPU fan and make sure it keeps spinning.
Other thing is..it could be what you say..faulty sensor.
dunkster
1,473
Your description sounds like the behavior of a CPU without a heatsink, or possibly a partial or edge-contact between CPU and heatsink.
Check the physical mounting of the heatsink for flat full-surface contact. If your heatsink has an edge-relief, it's there to clear the hinged region of the CPU socket. Any other orientation will make it impossible for full-surface contact.
Mount the CPU and heatsink before installing the motherboard, so you can be certain that the heatsink is mounted flush with the CPU.
Hope this helps!
wpshooter
1,662
What thermal compound/material are you using and please describe how you are applying it ?
Thanks.
P. S. - Where did you get this CPU and motherboard ? Are they new (probably not) or are they used !!!
Steaksauce
255
You sure you have the right heatsink? What model are you using?
Some HS designed for Intel socket 423 or 370 will fit on a socket A, but they have a little notch running across one side of the bottom of the heatsink. socket A should have a flat bottom.
