System of linear equations question
Ultima
edit:
Solved.
Thanks for your help guys, and I got a response back from my teacher.
Here is what he says:
Hi Kevin, all you step are correct and from the last matrix you can
draw the conlusion, namely this system is always solvable for any b.
In fact you can read off the solution y=(b-4)/12 etc. ITI
Orig. Message
I have a test tomorrow and I'm not sure how to solve these types of problems. Someone please help 🙂
For which values of b the following linear system is consistent?
x - 3y = 2
2x + 6y = b
2x - 6y = 4
I can get the 12y = b - 4 from reducing the matrix, as I end up with:
[ 1 -3 2 ]
[ 0 12 b-4]
[ 0 0 0]
But how does this tell me which values of b this system is consistent. That's what I forget.
Isolate a variable. Say x. So you have x = 2 + 3y
So you have 2x + 6y = b which is 2 (2+3y) + 6y = b
or 4 + 6y + 6y = b or 4 +12y = b
12y = b - 4
y = (b-4)/12
EDIT: yes I know I transposed some numbers earlier.
12y = b - 4
y = (b-4)/12
in Liniear Algebra, there is a different format to accomplish this. I'm pretty sure it involves putting them in a matrix, reducing the matrix, and then shuffling things around. This definitely isn't a regular algebra prob.
12y = b - 4
y = (b-4)/12
yeah i am sure your professor doesn't want a simple subsituttion, u have to put it into a matrix and do row reductions
12y = b - 4
y = (b-4)/12
Right. I can get the 12y = b - 4 from reducing the matrix, as I end up with:
[ 1 -3 2 ]
[ 0 12 b-4]
[ 0 0 0]
12y = b - 4
y = (b-4)/12
I took HS math, I swear. I forgot about Matrices. I know they exist and what they look like but forgot how to do it. 🙁
x - 3y = 2
2x + 6y = b
2x - 6y = 4
[ 1 -3 2 ]
[ 0 12 b-4]
[ 0 0 0]
Dump it in a matrix. Solve B such that the determinent is.... 0? Btw.. I believe you screwed something up in your above matrix example.
x - 3y = 2
2x + 6y = b
2x - 6y = 4
[1 -3] [2]
[2 6] [B ]
[2 -6] [4]
[2 -6] [4]
[2 6]
[0 0] [0]
[2 -6] [4]
[4 0] [b+4]
[0 0] [0]
[2 0] [b/2+2]
[0 -6] [2-b/2]
[0 0] [0]
[1 0] [b/4+1]
[0 1] [-1/3+b/12]
[0 0] [0]
x - 3y = 2
2x + 6y = b
2x - 6y = 4
[ 1 -3 2 ]
[ 0 12 b-4]
[ 0 0 0]
FAWK... nm. You row reduced right. What's the definition of consistant? Because b could be anything and you could find a corresponding x and y.
Originally posted by: Orsorum
x - 3y = 2
2x + 6y = b
2x - 6y = 4
[1 -3] [2]
[2 6] [B ]
[2 -6] [4]
[2 -6] [4]
[2 6]
[0 0] [0]
[2 -6] [4]
[4 0] [b+4]
[0 0] [0]
[2 0] [b/2+2]
[0 -6] [2-b/2]
[0 0] [0]
[1 0] [b/4+1]
[0 1] [-1/3+b/12]
[0 0] [0]
aye..finally..someone who knows what he is talking about
Row reduced to get to reduced echelon....solve....answer..easy...read your damn book😛
