Hello. I'm having a very annoying issue with my system; here's the details:
Gigabyte P35 DS3R
Intel Core 2 Duo E6320
2 GB Crucial Ballistix
EVGA 8800 GTS
XCLIO Goodpower 500W (original)
Antec Earthwatts 500W (new)
Problem is that when turning the computer on, I'm getting 3 quick beeps and then it resets. After reset, it does the same thing, and then resets again. After the 2nd reset, it tries to boot, and again, 3 quick beeps and then shutdown. So it's pretty much I get 3 beeps and then it craps out, and after the 3rd restart, it just doesn't even try again.
Not sure what's going on here; the motnherboard manual says that continuous quick beeps means there's a power problem. I put in a different PSU that I had laying around (brand new Antec Earthwatts 500W); but there's no difference.
I've also tried rebuilding the entire system from scratch to make sure that everything is seated correctly, and that didn't solve it.
The system was working just fine this morning. Then I came back a short time later, and this problem started.
Does anyone have any suggestions?
Thanks,
RShick
Gigabyte P35 DS3R
EVGA 8800 GTS
Thanks,
RShick
