System Locks often, Help?
Akaz1976
2,810
Okay my system locks after its been inactive for some time. when i try to bring my system back to life after long inactivity, at first the mouse moves fine but once i click any program to start it freezes on me?
Also both in start up and shut down, my system goes to sleep for up 40-60sec (ie no HDD activity) thus it really increases boot and shut down times? any ideas?
corkyg
Elite Member | Peripherals
27,370
239
Turn off any AV background programs and disable power management. You should then enjoy a very stable system.
Akaz1976
2,810
i got monitor set up to shut down at 5 min and hDD at 10 min? since i keep my computer on at all times can i afford to shut these power mangemnt features off?
Doggiedog
12,780
You should definitely shut off all the power management functions (in your bios) if your PC locks up often.
That is a major cause of lockups.
Akaz1976
2,810
okay i have every thing already off (i checked) only following functions have some value to them because there is no option to disable them:
ACPI Sleep Type
AC Back Function
What values should there have?(i cant recall what my bios currently has) and does this have anything to do with system lock ups?
