System keeps rebooting after post!
BoBo T Lesnar
I have a brand new computer that I just built:
athlon 64 4000+
enermax liberty 620W
2 gigs crucial ballistix
Sapphire pure advantage crossfire mobo
x1800xt
for some reason when it goes to load windows it reboots. Not sure what's causing it...any suggestions?
when you say load, do you mean you trying to do a fresh install? If you are using an existing Operating system from an old motherboard, it will behave exactly like what you're describing
I misplaced the jumper 😱....I can get into the bios, but it still reboots....I'll try setting the cdrom to master and do a fresh install of xp.
