- Apr 30, 2002
- 15
- 0
- 0
All,
I have an older HP system with an ASUS A7V-VM motherboard; it takes pc133 ram. It came with 512 total, (2x256).
I recently bought 2x512 sticks. ( http://www.newegg.com/Product/Product.asp?Item=N82E16820159006 )
If I put both sticks of RAM in, the system will not boot.
With stick 1 in slot 1, and stick 2 in slot 2, the system gets past the bios flash screen, then hangs with a blank screen.
With stick 2 in slot 1, and stick 1 in slot 2, the system gets to the windows loading screen, flashes a blue screen for a small fraction of a second, and then reboots.
There are two sticks and two slots. I tested all four combinations of 1 stick and 1 slot. Every single one works and the system comes up fine with the 512 MB ram, but no matter what I tried I couldn't get it to work with both sticks.
It also works with one new stick and one old stick (for 768MB).
This is puzzling to me because individually it appears that no stick is busted and no slot is busted, but together they just don't work.
Any thoughts or ideas? (Short of trashing and replacing it, which has already come to mind.)
Thanks
Thanks
