- Dec 12, 2001
- 27,052
- 357
- 126
I wasn't sure where the best place to put this topic was so I thought "general hardware" was safe.
I am having so many issues with this current system it's not funny. my Q9550 is basically dead. I'm on my old E6400 and have none of the issues the Q9550 was giving me. I have swapped my PSU as well. I tried this current PSU which is a seasonic S12 600w unit with the Q9550 and it's no good. I have swapped the video card to a single 9600GT and it's no good with the Corsair TX750 and Q9550 installed. I even tried the E6400 and 9600GT on the Corsair PSU and no go. So the only way to get stable is to use the Seasonic 600w PSU, the 9600GT video card, and the E6400 CPU. The seasonic PSU doesn't handle the GTX295 well when it's under load.
I've decided it's time to start over and I'm moving to i7. Now my dilemma is that I really don't know which socket I want to go with. 1366 is easier to overclock with, I've just never built a 1366 system. I have built 2 1156 socket systems for friends but only very mild overclocking and basic systems. Not what I am going to go for. I'm planning to toss a Megahalem on for cooling the CPU. I've read about the differences between the 1366 platform and the 1156 platform. I also know that 1366 supposedly will get Gulftown CPUs down the road, I am aware of the 1156 socket issues. The problem for me is, I'm going back and forth on which socket to choose. I do believe I'm going to go with an EVGA board as the reviews are always stellar despite the price premium. I don't know if I want to go with 1366 and spend a bit more and do an i7 920 with triple channel memory, or if 1156 is the better option with an i7 860 and dual channel.
I know some of you have been trying to make the same decision. I am also not totally against the i5 750 if there is some reason it's a better option. I'm unaware of any issues HT brings up and whatnot so maybe that's a consideration? I honestly don't know. I have no personal experience on these sockets & CPUs other than a few simple builds that didn't go crazy on the overclocking and tweaking.
So if you've managed to read through my long winded babble I commend you, but pose a question to you at the same time. If you were going to build a new system around a new mobo/cpu/memory combo which socket would you go with? If you went 1156 would you go i5 750 or i7 860? To that end does anyone have experience with both maybe? I guess I need someone to tell me which to buy lol. I'm not nitpicking price here either, I mean if the system is going to be $900+ instead of $600+ then so be it. I'd rather spend more and get a better setup if that's what it takes. I've read the reviews and I see that both platforms are generally close in performance. The difference being so minor as to not worry about, performance wise. That's why it's so hard for me to decide. Do I care about the possibility of getting Gulftown CPUs, or do I want to save a bit of money initially?
Any thoughts?
Any thoughts?
