System.ini causing bsod on win me machine
PointlesS
so I have this computer that gives me a bsod when entering windows...the user said it just happened...they restarted and it just started happening...I'm able to get into safe mode so I did msconfig and selected selective startup...everything is checked but system.ini and it boots fine...but when I boot with system.ini checked it gives a bsod...the error code it gives me is:
0D:11A7:00000316
unsuprisingly the knowledge base is of no help...so I looked at the system.ini file...here's it's contents:
; *** DO NOT EDIT THIS FILE! ***
; This file was created by the System Configuration Utility as
; a placeholder for your SYSTEM.INI file. Your actual
; SYSTEM.INI file has been saved under the name SYSTEM.TSH.
[boot]
system.drv=system.drv
drivers=mmsystem.dll
user.exe=user.exe
gdi.exe=gdi.exe
sound.drv=mmsound.drv
dibeng.drv=dibeng.dll
comm.drv=comm.drv
mouse.drv=mouse.drv
keyboard.drv=keyboard.drv
shell=Explorer.exe
*DisplayFallback=0
[386Enh]
ebios=*ebios
device=*vshare
device=*dynapage
mouse=*vmouse, msmouse.vxd
device=*vcd
device=*vpd
device=*int13
woafont=dosapp.fon
keyboard=*vkd
display=*vdd,*vflatd
[drivers]
wavemapper=*.drv
MSACM.imaadpcm=*.acm
MSACM.msadpcm=*.acm
wave=mmsystem.dll
midi=mmsystem.dll
[mci]
cdaudio=mcicda.drv
sequencer=mciseq.drv
waveaudio=mciwave.drv
avivideo=mciavi.drv
videodisc=mcipionr.drv
vcr=mcivisca.drv
[drivers32]
MSACM.imaadpcm=imaadp32.acm
MSACM.msadpcm=msadp32.acm
MSACM.msgsm610=msgsm32.acm
MSACM.msg711=msg711.acm
MSACM.trspch=tssoft32.acm
vidc.CVID=iccvid.dll
VIDC.IV31=ir32_32.dll
VIDC.IV32=ir32_32.dll
vidc.MSVC=msvidc32.dll
VIDC.MRLE=msrle32.dll
msacm.lhacm=lhacm.acm
[Password Lists]
DEFAULT=C:\WINDOWS\DEFAU002.PWL
[TTFontDimenCache]
0 12=7 12
0 13=8 13
0 14=8 14
0 15=9 15
0 16=10 16
0 18=11 18
0 20=12 20
0 22=13 22
anything suspicious? I'm kinda at a loss...I'm doing some virus and adware scans right now to see if that helps...
