System Info in WinXP
rky60
1,077
Start>Programs>Accessories>System Tools>System Information will not open
Does anyone know why when i click on System Information nothing happens? Is it possibly i have something turned off somewhere? Is there another way of checking my IRQ?
Thanks for help :)
mastertech01
Moderator Emeritus Elite Member
Nov 13, 1999
11,875
282
Try going to start/run and type in msinfo32.exe and see if it opens. If that doesnt work maybe you just need to reboot your computer and try again
rky60
1,077
Thx for the help :) But that wouldn't open it either. I ran a search for it and it is there, checked the properties and the location shows up as
C:\Program Files\Common Files\Microsoft Shared\MSInfo
Created: Wednesday, February 06, 2002, 2:18:16 PM which is about when i installed XP
Modified: Thursday, August 23, 2001, 7:00:00 AM <----------Does that make any sense?
Accessed:Today, March 10, 2002, 6:11:22 PM <-----------Tried to access, no workie
I don't get any errors when usin the Run command or clicking on it from System Tools. Thanks again for the info :)
bacillus
14,517
can't recall if this works in xp but does work in win9x.
look in device manager under properties of "computer" which will be right at the top of the list!
