ASUS P5N-SLI board with Core2 CPU, 4gb RAM, 32-bit Vista Business, three SATA drives, mouse and keyboard on USB.
Problem is that the mouse (and entire system) seems to hiccup now and then -- for half a second or up to two seconds, particularly when drive activity is especially high. Mouse freezes and then suddenly jumps when the pause is over.
It sounds like an IRQ conflict to me and I tried toggling the BIOS setting to allow OS to set IRQ. I've plugged the mouse into different USB ports to try that, but not sure what else I can do. It's hard to reproduce on demand, but I'll notice it several times each hour when I have a lot of things open.
Any ideas to try? I *know* I should unplug everything, reinstall OS from scratch, etc. and start adding things back in. No time for that! Any less drastic measures you'd recommend? It might have started around the time I ghosted my C drive to a larger one and started using that, but not certain about that.
Thanks in advance!
Thanks in advance!
