System hanging frequently
mogans
52
Hi,
I'm just using Corsair force series 3 60 ssd.I have currently connected it to the sata 3 port with achi mode enabled.The problem is,my system hangs quiet frequently.When i connect the ssd to the sata 2 port its working fine.Any idea what might be the problem?
System Specs
Intel i7-950
Asus sabertooth x58
Puppies04
5,909
17
X58 doesn't have native SATA3 does it? If so you would probably be better off running on the SATA 2 ports anyway as the 3rd party controllers can be pains in the arse with this kind of problem.
If it makes you feel any better I doubt a 60gb SSD is going to saturate a SATA2 port anyway, it is the higher capacity drives that produce the really big bandwidth.
Schmide
5,798
1,125
Uninstall intel ahci drivers, then reinstall? I had one system that puked out for some odd reason with those drivers. This fixed it.
