System halts when coming out of standby - CPU reset due to overclock
nubietx
36
System will not resume operation when coming out of standby. Requires a reset-power off/on and then the system displays a
CPU reset due to system overlock message.
Even when system is running at normal clock this problem is experienced. System config has not been changed for 8+ months. Tried removing one memory SIM and same problem. If a memory SIM is placed in DD2 slot 2 it only produces a long beep (EITHER sim placed in slot 2 caused the long beep - but EITHER sim works fine if only in slot 1). Im thinking the biostar MB is toast.
Details of hardware
MB
tforce 965pt / 965ca914bs
BIOS
9/14/06
CPU
Core 2 Duo 1.86gighz
Memory
ocz DDR2-800/6400 2gig
Hard Drive
Western digital cavier 1600AAJS
Video Card
evga 7600gt
Sound Card
onboard
LAN
onboard
Optical Drive
pioneer CD-DVD - RW
Other Devices
n/a
Power Supply
Antec sp400
Operating System
Windows XP-SP2
nubietx
36
Yep, tried that - still same
Sorry for the late reply. I had just about given up on a solution.
thanks
taltamir
13,576
"System halts when coming out of standby - CPU reset due to overclock " - overclocking is known to degrade chips, meaning you need more voltage to keep them stable at the same speed that worked before.
Also... the HSF might be clogging up, reducing the cooling capacity.
And the PSU might be aging, causing power fluctuations.
And any of the components could have degraded and broken
And ...
Basically, clean your system, then test all your components at stock, if they work, find a new OC that works.
