System freezes for 1/2 sec every 2 seconds and LAN disconnects
sornywrx
Craziest thing I've ever seen and I thought I had seen it all. Fresh install of XP on a desktop on a brand new 1TB Seagate drive (replaced failing 320GB). Seemed to work ok, installed XP via the recovery disks (Sony Vaio), system booted up. I tried to copy the documents and pics back to the appropriate folders and when it got about halfway of the 85GB of data it would freeze. So I hooked the new drive up via a USB adapter to my laptop and copied the data via my laptop to the new drive and it worked fine.
Slapped the new drive back in the desktop, booted it up, and after it runs for a few minutes I get the balloon in the taskbar telling me the LAN has been disconnected (even though it hasn't and the connection and activity lights on the builtin ethernet are still lit up and flashing). As soon as that happens I notice if I move the mouse constantly it will move for 2 seconds fine then freezes for 1/2 a second then moves for 2 seconds and freezes for 1/2 a second, over and over, until I reboot then its fine for a WHILE before it does it again. I have updated all the drivers. I'm not sure if the onboard Ethernet is actually the problem (or its driver) or if it's just casualty of another problem. I was thinking memory possibly so I ram Memtest86 and it passed. Could be power supply I guess or possibly the new hard drive. Going to try running diagnostics on the drive tonight because I know it'll take quite a while on a 1TB drive.
Anyone have any ideas? I've never really seen anything like it and I've been doing desktop support for 12+ years and have worked on tens of thousands of machines. I'm afraid this could be an unusual motherboard problem and makes me second guess my initial diagnosis that the old hard drive was failing. I was sure it was just a cut and dry hard drive problem when the person told me chkdsk was running at XP's startup and found a lot of files it fixed but then would take HOURS to load the desktop after logging on.
I would check SATA cable, temps, onboard NIC. If possible, disable onboard NIC in the BIOS and see if that helps. Linux Live CD/USB would rule out a Windows driver issue. Given the age, I wouldn't be surprised if there were some bad caps.
Any exclamation points in your Device Manager? Sounds like a bad driver/conflicting driver if it's not something that Anon posted above.
Disable disk write caching. That causes major issues if XP tries to write to the pagefile and the pagefile sits on a bunch of bad sectors. It very well could be the hard drive failing. Check the smart data and download a hard drive scanner.
And yes, AnonymousUser's suggestions are ones to follow.
Some very good tips. I didn't even think about the SATA cable but that's a good one. I disabled the onboard NIC in XP while this was happening and as soon as I right clicked and clicked disable the mouse quit freezing and the machine acted fine. I'm going to leave it disabled while I try out some other things to see if there are any other problems or if the NIC was the root cause.
Running SeaTools on the new hard drive now to see if there's any errors with it. Hadn't checked the caps yet but I have seen some pretty crazy stuff happen when the caps are popped so it's definitely something to look at.
I was sure it was a driver issue at first but nothing is showing as a problem in device manager and I've tried both an old and new version of the NIC driver with no difference.
Checking the hard drive now... could be a bad drive even though it's brand new.
Thanks for the tips guys!
Welp the HD passed diagnostics so I opened the case up and this time removed the HUGE plastic duct for the CPU heatsink/fan. All the other caps looked fine but there's 2-3 that were covered by the duct that are bad. 2 are definitely bad, oozing out, and one looks bulged. I usually just buy another board instead of messing with caps but the only board I can find for this oddball model is $349 on some parts site, no listing on eBay or anything. So repair might be my only option. As long as there's not any tiny components to solder next to I think I'll be fine. I am not great at soldering because I have poor eyesight (even with glasses) so basic things like soldering new DC jacks on laptop boards is no problem but when I get around really tiny components I usually mess up.
