System for Photosop
andyr354
Wanting to build a system for the main purpose of digital imaging. I don't to any gaming really.
This is what I was working on:
Athlon 3000+
MSI K8T
and this corsair ram
http://www.newegg.com/app/view...mp;manufactory=BROWSE
Anybody think this will make PS run well. Takes a minute to convert a Minolta raw photo as well with my current sytem.
I already have the case/ps, hardrives, and video.
Jan 31, 2002
40,819
Totally unrelated, but if you have an older version of PS, use that. PSCS has the lovely "We are Adobe, assimilate your computer, resistance is futile" spyware. :p
- M4H
Markfw
May 16, 2002
27,097
16,014
I can;t say for sure, as I don;t use photoshop much, but I think it likes lots of ram (one gig or more), and make sure your PSU is a quality 350 watt or more, or it won't handle the new system.
EULA
940
Photoshop is definately more Ram hungry than processor hoarding. I've talked to photoshop salespeople, and they say that they've run photoshop with 3 or more gigs of ram, and It still could use more.
All depends on how many pictures of what type and size you plan on editing.
Anubis
78,712
427
tbqhwy.com
- M4H
you can dissable that
CS runs fine on my athlon M 2400+ @ 2.4 GHz 1 gig of ram
the more ram the better i would go with at LEAST a gig, i belive that PS can only handle up to 2 gigs so going over that is pointless
if you want stupidily fast speed go with a dul CPU setup and 2 gigs of ram
Fash HDDs help also
dmw16
7,608
Im a little confused on your wording. You mean the 3000+ is what you currently have? I think a 3000+ should be enough CPU power. I think if you want to spend some money on upgrades. Get yourself three 1gig sticks of PC3200 and a Raptor hard drive. that would probably be your best bet.
andyr354
DMW16:
I currently have an old origional athlon at 800mhz, 512mb ram, 30gb hd, 80gb hd, ATI all in wonder(older model)
I love the new shadow hightlight tool, the ability to work in 16bit, the support for RAW in CS and would not like to go back to 7
Shold I just save 80 bucks then and go with the 2500+ and buy more ram I guess.
What is the best bang for the buck board for the 2500?
On the pics they are 5m pixel. Jpegs are around 2.5mb in xfine mode, raws are 7.5mb. Start adding layers with PixelGeneius Sharpener and they get big real fast!
Kaido
Feb 14, 2004
50,752
6,780
- M4H
dude no joke. it takes forever for anything CS to start up on my computer, even Acrobat. I use a Dell 4600 for my graphics stuff - 2.8ghz p4, 512mb ddr333, 80gb 7200rpm seagate hdd, and a 9600xt Radeon. Not only that, but when I clean-installed XP Pro over the included XP Home and installed CS again, it made me call Adobe and re-register it XP-style (because I had it on another computer too, 2 comps per lic). If the software wasn't so dang good and useful, I'd drop it because of this lol.
kaizersose
1,196
- M4H
what spyware does it install?
thirdlegstump
Banned
Feb 12, 2001
8,713
My Mac using friend tells me you should get a Dual 2.5GHz G5 as it'll be smoother and way faster than any Peecee.
Anubis
78,712
427
tbqhwy.com
you coudl build a dual Opteron sys for 1/2 the price and it would be faster
Markfw
May 16, 2002
27,097
16,014
Yup....
