I have been running Autocad for 10 years so my experience with the program is more than adequate.
For a notebook configuration:
[*]at least 500mhz Intel processor
[*]256mb of ram(I would take the 64mb and upgrade to 256mb from Crucial.)
[*]32mb videocard
[*]5400rpm HD
[*]TFT display
[*]CD-RW for backups
I would not recommend a 4mb video card for Autocad 2000!
Here is Autodesk's system requirements:
<< System Requirements
[*]Intel Pentium 233?based PC
[*]Microsoft Windows 2000, Windows NT 4.0 (SP3 or later), Windows 98, Windows 95 (B or later)
[*]64MB RAM
[*]100MB disk space for typical installation
[*]64MB available for swap space
[*]1024x768x64K graphics card and color monitor
[*]CD-ROM drive
[*]Pointing device (mouse or digitizer)
To further boost AutoCAD performance
Increase system memory. This is your most cost-effective way to improve performance.
Increase free or "unconstrained" memory. Paging to disk is the worst bottleneck for any Windows application.
Upgrade your PC?s processor. This can greatly improve >>
Even though Autocad was designed to run on slower systems I would at least bump up the memory on the video card to 16mb and the system ram to 256mb.
For a desktop configuration:
Will your dad be working in 3D or strictly 2D?
If 2D is his only concern then I suggest:
[*]19" moinitor (I suggest an AG type flat screen)
[*]at least 128mb of PC133 CL=2(from Crucial of course!)
[*]at least a 500mhz Intel processor(A celeron would probably be sufficient.)
[*]Matrox G450 32mb DDR(just in case you want to add another monitor)
[*]Iomega 100mb Zip drive(cheapest solution for drawing backups)(or CD-RW?)
[*]Windows 2000 or Windows 98 SE
If 3D is going to be part of the equation then I suggest:
[*](2x) 17" AG flat screen(Samsung 700NF or liyama i70a)or (2x) 19" monitors if that is in your budget. Dual screens will allow to view rendering results on one monitor and work on the other or you can have 2 different 3D views displayed. When you are designing in 3D two monitors would come in very handy when working with multiple drawings and xref dwgs.You can get two excellent 17" monitors for the price of one 19" monitor.
[*]Dual Processor Motherboard (maybe Abit VP6,Microstar,Asus,or Tyan)
[*]at least 700mhz/100mhz processors
[*]At least 256mb of PC133 CL=2(Crucial of course!)
[*]Windows 2000 Professional
[*]CD-RW(Plextor,TDK, I guess something in the 12x/10x/32x range?But any will do because speed is not the issue. Rendering files can get pretty large so a Zip drive is really not practical because of price issues with the larger zip drives)
If it were me I would prefer the desktop over the notebook for running Autocad 2000. I think you would get better performance for the money on a desktop.
It really depends on the type of Autocad work you are doing. Heavy 3D(renderings and multiple 3d layouts) or intricate 2D dwgs(ie:contour maps,civil plans,or detailed architectural dwgs)=heavy ram ,heavy processor, and video card . Minimum system requirements are sufficient for most 2d.
