Proposed use: Adobe Photoshop, Premiere Pro and After Effects.
Nominally: 10-bit 4:2:0 Max 24 bit rate. Max duration ~1 hour but most work will be half hour or less.
I was playing around with configurations on newegg and came up with this as a WAGuess.
AMD Ryzen 9 5900X 12-Core
Radeon RX 6700 XT
64GB RAM
2TB SATA SSD, Wifi, USB 3.2, HDMI, Bluetooth, Display Port, Win 10 Home (Win 11 Pro upgrade)
This comes in around $2.5k We are okay going +/- 20% but obviously lower preferred 🙂
My gf will be doing video editing as her job not to mention her own webseries and we were looking for recommendations.
Why did I go with AMD and DDR4?
AMD for budget. I've been a fan since the K5.
DDR4 vs. DDR5 is nominal performance difference but greater stability. We definitely want to minimize crash/freezes.
Questions:
*I saw other threads on this issue...but they didn't get an answer and they were 2022 or older...
Thanks in advance!
Radeon RX 6700 XT
64GB RAM
Questions:
- We do not know if this is good enough, if something is missing, is it more than we need?
- Shall we go with Intel/Nvidia for the hardware rendering support instead?
- What did we forget?
- I snuck in 4k as a "wish" item. If it completely blows the budget we can do without but would like to leave the door open (i.e. not a dead-end config.)
Thanks in advance!
