I moved my HP system over to an Antec Mini P180 case and really can't say enough good things about the new case or the 10º drop in temperatures. Only issue is that I get a "System Fan Error" on boot up. The HP case had a 92mm case fan connected to the motherboard (ASUS board made for HP). The BIOS is a very watered down version with nothing about fans in it.
The Mini has a 120mm Antec Tri-Cool case fan in addition to the 200mm case fan on top. Not that I probably need to run the 120mm, but they are both set on Low and it is pretty quiet. I believe the issue is that the Antec Tri-Cool and a Scythe S-Flex that I have and also tried are not PWM fans and/or start at a voltage that the mobo does not recognize. I tried a 92mm Scythe fan (also not a PWM fan) and the error did not occur and it booted right up, so I'm assuming it has to do with the 92mm fan starting voltage being different than a 120mm fan.
I can hit "F2" and the system boots fine and runs fine. All of the fans are spinning and nothing is out of the ordinary once I hit F2 and continue with the boot. Since it appears that it is a voltage issue is there anyway to get the Antec, Scythe or even some other 120mm fan to start at a voltage that the 92mm fan starts at so the error does not occur?
Or could I I just jump the pins on the motheboard system fan header and connect to a regular 4 pin from the PSU (I have a 3 pin to 4 pin adapter and had planned on using that to begin with)?
Thanks, Bill
Thanks, Bill
