- Jan 15, 2005
- 4,327
- 1
- 0
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARGH!
That problem propped up at a LanParty once, and my system woudln't boot (ASUS P4P800-e Deluxe).
It happened to me twice before. Now it happened agian. Alright, after reading about this problem for over 4 hours, I figured out the solution.
When does this problem happen?
-When you shut off your system without shutting it down
-When your CPU overheats and it shuts itself off
-When you overclock and the computer shuts itself off (See above)
What others do to fix this problem
-If you read around some forums, people will say that they couldn't boot with their ASUS so they return it and get a different board (ex: Abit or something).
-Some people say replacing their PSU works/
-For some odd reason, by all this the VIDEO CARD is affected. Everytone with this problem seems to relate this to their video card.
-Everyone that tried to clear their CMOS says that clearing the CMOS won't work
My Hypothesis
-I think it's a video card conncetion problem. When you swap your motherboard with something else, the video card is obviously reseated onto the new motherboard and it "surprisingly" works
-When you get a new PSU, you connect the molex connector to the video card, and people claim that it works
Solution
Here's what I beleive to be the fix for most(aka NOTall of these problems:
-Be sure all your connections are firmly tucked in, and that your CPU isn't overheating.
-Disconnect the Molex connector from your graphics card, and reseat the graphics card, and put in the connecotr again
-If that doesn't work: then use a different molex connector
I really don't know why this is a "System failed CPU Test" problem, but what I did (see "Solution") made it work for me. I did the same thing at the LanParty, it worked too.
All I did was simply reconnect the 4-pin molex connector and that fixed the problem for me.
I hope this helps the people wth an ASUS P4P800-e Deluxe/ASUS P4C800-e Deluxe/ASUS A8V Deluxe (I see this problem on those boards typically).
I have a feeling that this issue has been resolved on the new ASUS boards (A8N-E/A8V-E/A8N-SLi).
-The Pentium Guy
My Hypothesis
Solution
-The Pentium Guy
