jmathews42
Ok I'll try and explain this as well as I can.
I have had this computer for about 2 years and this is the first 'real' problem I've had with it.
I was playing a game which was causing my sound to 'skip/pop' and would also cause the game to lag. A friend suggested that I update my drivers, which I did. I updated my graphic drivers and the driver for my onboard sound. This fixed my lag issue, but I didn't have any sound. None. I tried reinstalling my old drivers off the drivers' disk that came with the motherboard. The installation went till about 80% then my computer rebooted. And evertime it loads Windows (XP) it reboots again.
I grabbed a new hard drive an installed XP on it. It works but crashes/reboots often.
I'm thinking that maybe the drivers are still conflicting, so maybe reseting my BIOS?
Specs:
AMD 2000+
1GB Kingston
GeForce FX 5200
NEC DVD Burner
Mitsumi CD burner
1 80mm Fan
1 blower fan (PCI slot)
2 120 WD HDDs
400w power supply(forget which brand)
And again like I said I haven't had any problems with this setup until the driver update.
Specs:
AMD 2000+
1GB Kingston
GeForce FX 5200
NEC DVD Burner
Mitsumi CD burner
1 80mm Fan
2 120 WD HDDs
