System Crashing - CPU error? usually driver error...
mplutodh1
305
I have been experiencing a system crashes off and on and usually get the system driver error message where it can't locate the exact cause. Well tonight it crashed again with:
Hardware Failure: Contact Original Equipment Manufacturer
Thank you for submitting an error report. The error was likely caused by:
A hardware failure reported by your Central Processing Unit (CPU)
This behavior occurs because your computer processor detected an unrecoverable hardware error and reported it to Windows. For more information, contact the manufacturer of your computer.
NOTE: As a general rule, Microsoft recommends you backup your files on a regular basis in case of any unexpected hardware failures.
Anyone have any ideas? I followed the MS instrucitons on removing the IOMEGA driver that was found to be causing them at first but this one has me confused, CPU error?
Errors I have been getting on a regular basis after reboot:
Error Caused by a Device Driver
Thank you for submitting an error report. Microsoft is unable to specifically determine what caused the problem you reported. If you would like to try and troubleshoot the problem, please utilize the information listed below.
The Error that first came up, which I thought I followed the instructions to:
Solution Found: Contact Iomega® Corporation to obtain the update
Problem Description
Thank you for submitting an error report. The error was likely caused by Iomega Active Disk, IomegaWare, Iomega HotBurn or Iomega HotBurn Pro (iomdisk.sys).
Problem Resolution
Iomega Active Disk, IomegaWare, Iomega HotBurn or Iomega HotBurn Pro (iomdisk.sys) was created by Iomega® Corporation. Iomega® Corporation informed Microsoft that they have a solution available for the problem you reported. To learn more about the solution, Iomega® Corporation recommends that you visit the following website:
Goftp://ftp.iomega.com/beta/engl...patch-w32-x86-2454.zip
ColKurtz
429
Might be RAM - try swapping some of it out.. If you keep getting different errors at different times running different things, then it's more than likely RAM.
mplutodh1
305
Well isn't that great. Now that I think about it, it started happening about when I got my new ram... suck!
