- Aug 25, 2001
- 227
- 0
- 0
I recently built a new system and have been having some problems. The system crashes randomly when it is in use. I could be emptying the trash bin or simply drawing something in MS Paint when it happens. Overheating is not an issue, I'm getting very good temps with the SK-7 HSF
Here are the basic specs of the system:
AMD Athlon XP 2400+
512MB Crucial RAM (2x256MB DDR PC2700 - CT3264Z335)
Abit NF7 Motherboard (nForce2 Chipset)
Asus V8170DDR/SE Geforce4 MX440 64MB
Antec SmartPower 300W
Western Digital 80GB 8MB Cache
Plextor 48/24/48 CDRW
Floppy Drive
WinXP
I have formatted and reinstalled Windows and that did not work either. I have the latest nForce2 chipset drivers installed and have also flashed the BIOS to the latest version with no success.
Right now I'm suspecting that there is a problem with the memory. I heard nForce2 based boards are not liking some models of Crucial's PC2700 RAM, but I've heard this issue is mainly with their 512MB module, so I'm not sure.
I have my FSB running at 166Mhz right now, but have also set it to 133Mhz to see if that would help and it did not. I adjusted a few memory related settings in the BIOS and that helped a little, but I'm still getting crashes (just less frequently).
Another problem I'm having is the system will not always detecting the mouse. The mouse is getting power, I can see the laser light up and everything, but it is not listed in the device manager in Windows XP. I need to restart the system and sometimes it will figure out that there is a mouse connected and decide to work, sometimes not.
Anyone have any suggestions? I've been wracking my brain trying to figure this out.
Thanks
Andrew
Edit: The mouse is connected to a PS/2 port.
AMD Athlon XP 2400+
Floppy Drive
WinXP
Thanks
Andrew
