System/CPU too hot?
Jonnses
21
I just build a new system and was wondering if the temperature in my system & cpu too hot. I'm using the Winbond Hardware software Abit supplied with the KX333R to read the output.
On average theses are the readings I get:
Vcore: 1.80
Vio: 3.5
+5V: 4.7
+12V: 12.2
APG: 1.5
DDR: 2.6
Vsb: 4.92
Vbat: 3.02
Fan Speed--
CPU Fan: N/A
Chassis Fan: 4,688 RMP
System Temp: 35C
CPU Temp: 51C
The weird thing is the CPU fan I have mounted on it is working, but it the software doesn't gauge its fan speed. I'm using some generic CPU fan thats supposed to be fine on a Duron 1.3 Ghz. Should I be concern about the temperature and get a new CPU fan? [any recommendation on a good cheap fan?] Isn't 50C approx. 100F? I already have two case fans, and a pci outtake fan under my AGP card. Thx for the help!
OulOat
5,769
Lol, why don't you try reading through all the previous threads, they all said that anything less than 70 won't hurt your cpu.
EKAtBzboyz
323
default vcore is supposed to be 1.75 on tbird/axp and 1.65 on tbreds...
maybe go into bios and see if you can change that
it might bring it down a bit
but other than that you are ok
