System configuration utility
Aug 30, 2004
29
i'm having a problem with this program. it keeps loading up at startup. i'm not sure what's exactly causing this, but all the settings in the app is default/normal. the only time i loaded msconfig was to /noguiboot because a friend recommended to check the box so that xp would load faster which i found out later it didnt help performance at all and was plain ol bs. that /noguiboot is unchecked now and still, msconfig keeps loading at startup. i also checked the box to bypass this app reloading again, but it doesnt work either. could my system be infected by a virus? adware? trojans?
zimu
6,209
don't think its a virus/adware/bug. try creating a new user in XP and log on using the new account, does it still pop up?
