Howdy, y'all. I would appreciate feedback on my proposed system. I've spent the past few weeks of my spare time researching this, so I hope I don't come off as a complete idiot.
Intended use: #1 - photo editing/printing, #2 - Gaming (MMORPGs mostly)
Constrants: Amount to spend ~$1,000
MOBO: MSI K8N Neo4 Platinum Ultra Socket 939 NVIDIA nForce4 ($126)
CPU: AMD Athlon 64 3200+ Venice 1GHz FSB 512KB L2 Cache Socket 939 ($190)
RAM: CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR ($87)
GRAPHICS CARD: SAPPHIRE 100105-BL Radeon X800XL 256MB 256-bit GDDR3 PCIe x16 ($289)
HDD: Seagate Barracuda 7200.8 250GB 7200 RPM ($123)
CASE: Antec SONATA II Piano Black Steel ATX Mid Tower ($104)
PSU: 450Watt SmartPower 2.0 ATX 12V V2.0 (included with case)
DVD: NEC Black Model #: ND-3540A Black ($46)
TOTAL: $965 (price of components only, no shipping or tax incl, no rebates deducted)
The hardest decision of all was deciding which motherboard to use. I've read good things and bad things on this mobo, and, well, all motherboards, but this seemed to have a good feature set for a good price (especially with the current $25 rebate) relative to its peers. The balance of reviews seemed quite positive, so I'm willing to roll my dice with MSI unless a better alternative is put forward.
Originally I was considering the SLI version, but decided against it. The x800xl video card appears to be the best bargain on the market at the moment, and is not SLI compliant. Comparing the SLI with a 6800gt to the Ultra with the x800xl I can save at least $70. However, one place the SLI is superior is integrated sound, with its 24-bit Creative compared to the Ultra's Realtek. I've read that the Creative uses less resources and has superior sound quality, but I wasn't clear on whether the performance gain during gaming or other applications was significant. I guess I could always add the Creative 24-bit card for $29. Is the 24 bit sound really worth it? Am I hindering my upgradeability by not going SLI?
I've also got the impression that this is one of the better boards for noobs thanks to the plug-and-play BIOS, making setting up an easier process. Is there any credance to this claim?
Most of the remaining choices seemed uncontroversial: Sapphire graphics card based on price and reputation; Seagate HDD for 5yr Warranty and performance (it's no Raptor speedwise, but then again, it's no Raptor $wise).
The only other questionable choice was in case and PSU. Clearly a cost saving measure here. The Sonata II was not my first choice looks/features-wise. I would prefer a nice Lian-Li or Antec P180, but these don't include a decent PSU. The above rig is non-SLI, and won't be overclocked to any serious degree so I thought this PSU seemed quite up to the task, with even some room to grow.
Sorry if this was long winded, but I felt that most system check requests were a little short winded. I'm really psyched about my first build, but want to take the time and do it right. I'm mostly concerned with the choice of motherboard and the PSU. All advice will be most appreciated.
Thanks,
Hoss
Thanks,
Hoss
