System Build
Fletch450
9
I am building a new PC and thought I would post what hardware I am going to use and see if any of you gurus have any pointers or comments on the system, I am not a big gamer just looking for something that will last a while with some good performance.
COOLMAX CW-650T EPS12V 650W Aluminum ATX v2.01 APFC Power Supply w/ "SLI" - Retail
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive - OEM
ASUS M2N32-SLI Deluxe Wireless Edition Socket AM2 NVIDIA nForce 590 SLI MCP ATX AMD Motherboard - Retail
CORSAIR XMS2 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory - Retail
2 of them
Thermaltake Armor Series VA8003BWS Black Full Tower Case w/ 25CM Fan ? Retail
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Video Card - Retail
AMD Athlon 64 FX-62 Windsor 2.8GHz 2 x 1MB L2 Cache Socket AM2 Dual Core Processor - Retail
So what do you think?
Sinn707
210
1. Bad psu choice, get Corsair 520HX instead
2. You should consider going with Intel. E6750 will be released on July 22nd, GIGABYTE GA-P35-DS3R will work great with it.
3. Get a dual channel ram kit, this one is good.
Rest looks good, Good luck.
Fletch450
9
I havent seen anything on the PSU, do they have problems?
