- Jul 11, 2000
- 29,932
- 3
- 81
Current Rig:
Built in 2002
http://support.asus.com/cpusup...e=en-us&model=A7M266-D
A7M266-D motherboard 2 athlon mp 1600 cpu's
2 gb memory
128 mb ati vga vid card single output about 4 years old
2 ide hard drives sufficient space no issues
My problem:
I need a dual output vid card that will be compatible. Can't find any as the board is so old.
Solution:
Find me a good card that will be compatible
or
a new mobo/cpu/mem/graphics combo.
I use this PC for business. I have graphics itensive applications Adobe CS3 mastersuite. I am not a PC gamer. I do alot of multimedia though.
so is it worth it to just upgrade the graphics card or get a new set up and sell off my old parts? I am just worried because as time goes on its going to be more difficult to maintain this rig to keep up with my demands.
UPDATE
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822136284
Return Policy: Limited 30-Day Return Policy
$149.99
EVGA 512-P3-N975-AR GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Item #: N82E16814130380
-$10.00 Instant
$25.00 Mail-in Rebate
$134.99
$124.99
Kingston HyperX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model KHX8500AD2K2/4GR - Retail
Item #: N82E16820104060
Return Policy: Memory (Modules, USB) Return Policy
$30.00 Mail-in Rebate
$92.99
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
Item #: N82E16813131299
Protect Your Investment (expand for options)
$15.00 Mail-in Rebate
$134.99
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
Item #: N82E16835186134
Return Policy: Standard Return Policy
-$10.00 Instant
$36.99
$26.99
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Processor Model BX80569Q9550 - Retail
Item #: N82E16819115041
Return Policy: Processors (CPUs) Return Policy
I'm going to recycle the case and antec 600w psu which are both only < 2 years old
So will i be good to go with this?
UPDATE 11-04-08
Ok I got everything put together and installed. Goto fire it up the first time. Everything lights up case light, mobo light, fans, vid card fan.....power everywhere.
No POST beeps. Monitor is blank. No signal.
Uhhhh wtf?
Built in 2002
2 gb memory
My problem:
Solution:
or
UPDATE
$149.99
-$10.00 Instant
$134.99
$124.99
$92.99
$134.99
-$10.00 Instant
$36.99
$26.99
UPDATE 11-04-08
Uhhhh wtf?
