System Build Suggestions
segejames
Antec Performance One P180B $129.99
EVGA 122-CK-NF63-TR LGA 775 NVIDIA nForce 680i SLI Motherboard - $159.99
EVGA 256-P2-N636-AR GeForce 7950GT 256MB GDDR3 PCI Express x16 HDCP $199.99
OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply - $149.99 -
Intel Core 2 Duo E6420 Conroe 2.13GHz LGA 775 Processor Model $186.00
Update mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual -$89
Total cost is $1,005.00 shipped,taxed to my door.
I'm looking for any suggestions on parts that might work better but keeping it to a close price. I will not be doing SLI, atm, nor O/C'ing. It will be for casual gaming, nothing that requires a GF8 card.
I have the sata and optical drives so that is not a problem. Plus a legit XP cd.
Thanks for any suggestions.
Vogel515
249
Welcome to the forums... but do your research before posting.
If you're not doing SLI don't get an SLI board. It's not worth the extra money. Get a p965 board. The gigabyte ds3 one is popular.
Your power supply is over kill, get something between 400-520 watts from a reputable company like seasonic, corsair, PC&C, or FSP.
You can get cheaper ram, you will not need anything faster than DDR2 667... 533 would even suffice - you're not overclock so 800 is overkill.
The case is nice, the graphics card is nice, but you can get a 7900 GS for $106 now, that would probably do for casual gaming. If you're going to go for a 7950GT, might as well take the money I saved you on other components and get a 8800.
To save more you could even step back on the Intel Core 2 Duo, but I plan on getting the same one so I won't push much there.
Boyo
1,406
YOur PSU is way overkill. A 500W Corsair or Seasonic would do better. Keep the RAM, it's only $89.00 and since you are only doing casual gaming, I might just go ahead and keep the 7950GT. Otherwise it looks good.
