- Jul 25, 2007
- 314
- 0
- 71
Alright, well, I've been reading the forums for quite awhile and finally joined up because I am presented with a conundrum of sorts and I can't make a decision. I recently got on scholarship so I'm going to spend my financial aid for fall semester to do a much needed upgrade to my desktop. At any rate, I can't decide on two things, which mobo/gfx combo to go with and which cpu cooler to go with. I'm an experienced system builder, but I'm not very decisive, but I figured you guys would know. At the moment my parts list is as follows:
<snip>
My main tasks are going to be gaming, watching HD movies, browsing porn, and encoding HD video in x264. I plan to OC the Q6600 to 3.2GHz. Basically, I had some concerns because I heard the 680i was not a stable OCer and that it had issues OCing with all 4 DIMM slots filled. I've heard several people say the P35 chipset is better, and that losing SLI isn't a big deal, so that's my conundrum there. My other issue is that I don't really like tower coolers and the Gemini2 seems superb, but I also am a Thermalright fanboy and have heard wonderous things about the Ultra120 Extreme. I'm not sure which route will produce better results and have the best mobo compatibility with whichever board I go with. It also might be worth noting that RAID is important to me, and I've heard of issues using RAID on all the P35 boards.
Thanks in advance.
UPDATE:
My new build, based on this advice is as follows:
Case: Cooler Master Stacker II
PSU: Enermax Infinity 720W (already purchased)
Mobo: See below
CPU: Q6600 (G0)
RAM: 2x Crucial Ballistix DDR21066 DC Kit
GFX: Geforce 8800GTX
System Drive: 150GB WD Raptor
Storage Drives: 4x Samsung Spinpoint T 500GB (in RAID 5?)
Optical Drive: Samsung 18x SATA DVD burner
CPU Cooler: Thermalright Ultra-120 Extreme (w/ 120mm hi-speed Panaflo)
Thermal Paste: Masscool Shin-Etsu
Okay, so I've gotten everything figured out but the mobo, and I have dropped my price down to just under my budget BR right now (which means it will be way under-budget by the time I build). I'm really leaning towards the Asus P5K Deluxe but I've also heard really good things about Gigabyte P35-DQ6. I'm a little concerned about the heatpiping on the mobo and whether that would block my cooler, which makes me also interested in the Gigabyte P35-DS3P which has a little more conservative heatpiping but the same featureset otherwise.
I'm not going to RAID the raptors anymore, instead opting for a larger single raptor, and I may still raid the 500giggers, but maybe not. At any rate, either way that eliminates any worries about the quality or usage of onboard RAID, which means I don't have to worry about finding a decent RAID controller that can handle both the subsystem and the internal drives. So, as soon as I figure out which mobo I'm using, I'm pretty much set.
<snip>
Thanks in advance.
UPDATE:
Mobo: See below
CPU: Q6600 (G0)
