so i have a winxp/sp2 system (xp333r and a 2200+ thoroughbred).
everything was working great, then a few days ago it started crawling during boot, right when it got to loading the os after verifying dmi pool data
i tested w/memtest86, no errors. also all pc-check tests pass fine.
i thought HD maybe, i installed another known good one.
installed clean os...but during drive examination/detection it took maybe 5 minutes, and took another 5 when detecting existing operating system, then the whole install took much much longer than usual, and the boot after the install was just as long as before....it was CRAWLING. it took maybe 10 mins to boot into OS, and after it was in the os, it was way too slow to be usable.
thought it was a bad ide controller, swapped drive to secondary, and then to ide raid controller....same issue, reset dmi in bios, it redetected, still nothing.
could it be cmos batt? doesn't seem like it is, i dont know. i'm ready to swap mb/proc
any ideas?
thanks,
Leon
any ideas?
thanks,
Leon
