I have recently purchased the following:
Thermaltake VA3000 Case (120mm fan on the front, back, and 90mm side fan)
MSI K8N Neo2 Platinum Motherboard
Antec Trueblue 480w PSU
OCZ EL Revision 2 PC3200 2x512mb
NEC 1.44mb Floppy
Western Digital 36GB 10k RPM Raptor SATA
NEC ND-3500A DVD+ CD-RW
Leadtek Geforce 6800GT
Sound Blaster Audigy2 ZS
Now what I am curious to know is the following:
1. CPU? CPU? CPU? I would really like to get a hold of an Athlon 64 FX-53 primarily because I do not overclock and I don't plan to build again for at least 3 years, but is the $800 price tag worth it? Is it worth it for 3 years or more of performance?
2. Heat sink and Fan requets for the chosen CPU? Are standard retail HSF good enough to keep the system cool and stable when not oc'ing? Are there any recommendations that would compliment my setup thus far?
3. Monitor! LCD or CRT? Yes I am a gamer and I do media editing (photoshop, flash, etc) but with the constant rumors of ghosting on the LCD's, is it worth it to move to that technology yet? If so, any recommendations on an LCD of choice for gamers?
4. Finally, are there any foreseeable issues here to the trained eye that I should be aware of when building this system? Drivers, bios versions, compatability issues, heat/temp issues, performance issues?
Thanks tremendously!
NEC 1.44mb Floppy
