beatle
I'm running 2008 w/HyperV and I'm trying to Sysprep a 2003 R2 VM to be used as a base for other OS installs. I make an answer file and then run Sysprep on the base build, reseal, and shut down the VM. I then make a copy of the VHD and create a new VM with it. When it boots up it doesn't go into the mini setup, it goes right into Windows as if I didn't sysprep the box at all. However, when I restart the base 2003 VM that I ran Sysprep on, it starts mini setup as I expect it to. What am I missing here so that my copy of the VHD works the same as the original?
