GnatGoSplat
My machine is up 24/7 running Windows 2003. I never had problems with it, until yesterday. I decided to try Nero Recode & burn a video DVD and it just won't finish.
My hardware is:
Asus M2N nVidia MCP61 chipset motherboard
AMD X2 3800+ CPU
Geforce 7100 video
Maxtor/Seagate 320GB SATA
NEC ND-3540A DVD burner
During the recode/burning process, both cores are pretty much pegged at 100%. When it crashes, it's weird. All disk I/O stops. I have graphical CPU activity gauges, and they spool down to near 0 and freeze. The mouse still works. Clicking on windows still works. If I try to close a window, it will say "(Not Responding)". Num lock, caps lock, all those keys till work. CTRL-ALT-DEL or CTRL-SHIFT-ESC don't do anything. The clock doesn't advance. The drives are never accessed.
I suspected a temperature problem because running ASUS Probe II, the CPU temp kept climbing up to 65C and MB Temperature is 45C. I thought maybe my CPU was overheating, because I was theorizing that maybe the motherboard stops CPU processing until the temperature goes back down. However, I let it sit 15-minutes and it never recovered. I ended up with a coaster since it finished the burn halfway.
I discovered in BIOS that I had Q-Fan turned on, and it doesn't go to full speed until 70C. that seemed too hot, so I tried turning it off. Now CPU temps max out at 60C, but it still locks up. The second time, luckily it hadn't begun burning yet so I didn't lose a DVD that time. I've read some sites that this CPU should still work up to 70C.
Now I wonder if maybe it wasn't the CPU after all, maybe the chipset is crashing. All that continuous I/O, maybe it was overheating? It does run scalding hot to the touch and only has a tiny passive cooler about 1/4" tall.
Any ideas which is the cause of the problem?
My hardware is:
AMD X2 3800+ CPU
Geforce 7100 video
