Hello friends,
I just purchased the Google WiFi 3 puck system to replace my AT&T router (keeping modem portion).
I was told to do this in steps and I would like to know if I have this right so I can keep the same SSID and password and avoid Double NAT (not sure what that is).
Step 1; Open the AT&T page on computer.
Step 2; Go into settings an enable "detection of router behind router."
Step 3; Go to WiFi settings and disable both 2.4 and 5.0.
Step 4; Save. (Not sure if I need to power down and restart?)
Step 5; Plug the Ethernet cable into Google WiFi (1st puck) and turn on.
Step 6; Open app on phone and when prompted, add in the same SSID and password as you had on AT&T.
Step 7; Save and connect.
Step 8; I should now see the same name in my WiFi search as I had with AT&T.
Step 8; If all goes well at this point, all my current electronics, phone, TV, tablets, wireless cameras shouldstill be connected.
Please let me know if I missed anything. I would like to do this with no issues like Double NAT.
Thank you all for your support.
Mikey
Mikey
