I went from a GTX 680 to GTX 970. I started noticing a stronger vibration/low hum from my computer. I narrowed it down to PSU (touching it, I could feel the vibration matching the low hum.) Since the 970 uses less power than the 680, it seemed confusing why this would happen (seems it would be easier on the PSU.)
Anyway, my PSU is module and the two cables, I use for my video card, are two 6+2pin connectors. At first I was going to just plug them into different slots on PSU, but I decided to just switch them on the card. Vibration went away.
What would cause the vibration in PSU from the initial 6+2 slots I used?
