Switch from DSL to Cable Modem. Effect on my home network?
ChiknHead
646
I am getting ready to switch from DSL to cable (Adelphia).
I have a wireless home network via a Netgear MR314 (Cable/DSL) wireless router.
My question is:
Is there a certian modem I should buy to replace my DSL modem so that it wont mess up my network?
I assume all I need out of the modem is that it "auto logs" onto the internet?
Any help is appreciated!
Thanks
mboy
3,309
If your DSL was eityher providing a static IP or was using PPOE, then you have to set your router to DHCP and disable the PPOE settings. Otherwise, you will probably just notice faster internet connection with your LAN Pc's :)
JackMDS
29,545
422
My question is:
Thanks
Atter the Cable Modem is connetcetd.
1. Change the Router Seting from PPPOE to Dynamic IP.
2. If neccessary Clone the MAC that would registred with the Cable ISP.
3. Run DrTCP and Change the MTU to 1492.
Download DrTCP: <a target=new class=ftalternatingbarlinklarge href="http://www.dslre
ports.com/front/DRTCP021.exe">http://www.dslreports.com/front/DRTCP021.exe</a>
Run the program, it will show the current settings of TCP/IP parameters. Write them down.
You can change any variable that you want, click Apply, and reboot the computer, if no good; you can always change to your original values.
Start with:
MaxMTU - DSL =1492 Cable=1500 ISDN =1322 DialUp=576
Tcp Receive - 256960
Window Scaling - Yes
Time Stamping - No
Selective Acks - Yes
Path MTU Discovery - Yes.
Black Hole - NO
Max Duplicate - 2
TTL - 64
Notice it said above Start with
These settings are not written in "stone" there is variability depending on the computer other setting. So try few setting and measure your Download for each setting.
In addition, in case a person has a Router the Router's MTU if set differently can affect the general MTU.
Link: www.ezlan.net - Measuring the "Speed" of Internet Connection.
