Hi,
Sorry for this being long, I'm hoping someone will spot the user error or bad process I'm using.
I was hoping someone might have a suggestion for me. I have a new hard drive and thought it would be a good chance to jump from Vista Home Premium 32bit to the same version 64bit. I added the drive, changed the boot order in BIOS and that was about the only thing that worked right.
A guy at work provided the 64bit ISO from his MSDN account. Everything I've read says all the versions are on the disk and just the key is what determines. I have the 32bit OEM/systembuilder disk. From what I understand, my licensing is good for the version, not the bit level. With the exception of changing the boot order, I'm running the same hardware, so I don't think there should be a concern there. His disk comes up as version 6001 (SP1 included) after I burned it to a dvd.
Anyway, I boot up the dvd, select the new drive which is already showing as drive 0. It never asks me for my license to pick the proper version, it just installs ultimate. On the first boot, I got a blue screen and it came back in safe mode. On rebooting again, it looked good. I checked my Vista Experience score and had 1.0 because of video drivers. So, I managed to get to the vendor's website and download and install the drivers. On reboot, another blue screen and yet another reboot.
Now things looked somewhat decent (except the blue screen experiences). I wanted to get windows updates to make sure I have the latest patches before installing anything else. I'm pretty sure I need my permanent license know for windows genuine whatever. I plug in my key code and it says it's not valid. I know it thinks it's Ultimate and I'm trying to use a home premium key, so I go online to look to for answers. IE locks and restarts due to some unknown error. It starts doing it on every page to the point that I can't even get my search term typed in before IE crashes. Then explorer crashes and the whole desktop reloads.
So, I figure I missed something on the install and redo the entire installation again. Same basic results, the system is completely unusable & everything causes process failures and restarts.
Is it likely that my source ISO was bad somehow? Is there some other secret install I can do when booting off the DVD to get more options?
My only other idea is to clone my current drive to the new one and then try to do the fresh install when it can detect the current version on the drive. I was really hoping for as clean of an install as possible, but so far it's a complete failure. My concern with this option is related to the poor decision I had made previously with setting up an OS partition and Data partition on the old drive. I absolutely hate that, it's inefficient on the space (since that was a smaller drive) and now my data seems spread around 3 folders while I was figuring out how to move off of C:\user\username, now I have a few things straggling there, some in d:\user\username, and somehow d:\userdata\username.
I had great hopes that I could just install on the blank new drive, use Vista easy transfer to a usb external drive, and have it put things back into a single C:\ drive with all of the folders not spread all over hell.
Thanks for taking the time to read through this mess. I'm sure it's an id-10-t error, but I can't find any explanation for why the system is so unstable.
