SWISH! HELP
Qzruh
122
I never use swish before, but in Flash editor, there are menu to generate html coding to load Flash animation into web....so all you have to do is copy and paste those code into your html file.
just hit F1 and search for the answer with the keyword generate, coding, or html
good luck
LostBoy
378
You might also try the forum at the Swish site. Many people there are very helpful.
