I won a swiftech 462 heatsink in a contest. Its an used one.
I am trying to figure out how to connect it to a 80x80 fan. Since it didn't came with any mounting or screw to connect it to the fan. This is the older swiftech 462, the one that doesnt have corner cut off.
I saw this fan bracket on swiftech's site, but it doesn't look like it would fit a 80x80 fan. The top screw has offset distance from the buttom screw. Looking at a 80x80 fan over my swiftech HS, the holes goes straight down with no offset distance between them.
What should i do? Are there screws i can buy? where?
