- Sep 21, 2002
- 64,795
- 84
- 91
http://www.csrealism.com/
http://www.csrealism.com/html/feingame.html for screen shots
had to wait till now for 1.6 version. i used to use it with 1.5 and the sad truth is the models are far superior to those in the new cs condition zero rip off. much higher polygon counts, no absurd edges
now to reinstall cs
edit The new detailled textures only work when you have set r_detailtextures "1" in your config.cfg found in your /cstrike directory.
running the csru config file might do the same thing, i didn't check. seems you can turn on/off this pack
now to reinstall cs
