SweClockers: Geforce GTX 590 burns @ 772MHz & 1.025V
3DVagabond
11,951
204
Testing? I doubt they had much chance for it. Clearly they did not expect 6990 to scale so well, so they thought that 2x downclocked 580s on 1 pcb will be good enough to beat 6990... Remember the 2 day delay due to drivers? I bet that's because they never designed the 590 to go above 500MHz and so, they had to do a 6 months worth of catching up in 2 weeks, to push it to semi competitive range of 6xxMHz... The problem with 590 is exactly the same problem as is with 580, it is too power hungry.
590 can be a great card if:
1. You clock it at 580 speeds
2. You give it 580 voltages
3. You install much much better power circuitry (This is what is failing now)
4. You install a cooler capable of 600+ watts of thermal capacity
5. You give it 700W of electrical power.
The card specs were already set before that. Last minute review drivers would be my guess. They've actually just released another new driver today (Mar 25th).
Joseph F
3,522
God, I'm glad they didn't release this. (unless it were on 28nm. *drool)
sandorski
70,225
5,801
Where's your proof of that statement, HM? Or are you just so green loyal that you'll just simply lie and hope it's accepted as fact? Or is it just that you cannot fathom anyone criticizing Nvidia products unless they're a paid AMD employee....which is just what you're saying? I thought that sort of statement was not within this sub-forum's guidelines.
Guess exceptions are always made, though. :)
That said, if AMD wants to Pay me, PM me ASAP! :D
Seero
1,456
Nonsense.
CPUs and GPUs are usually overclockable. The failure mode usually being that they don't overclock very well. Not blowing up. Especially not six out of a limited review set.
Some people got lucky since their cards did not blow up?
BFG10K is right about overclock. The idea of OC isn't about manufacturer not max out the performance, but rather for people who knows about electronics, spend time to read and understand varies parts/specs and how they work together to actually squeeze some more performance out of tolerance from mass production.
But now, people blindly OC just before some forum poster say they did it. Manufacturer added GUI and dynamic voltage adjustment for easier OC, but many mis-understood as it is safe to OC.
So yes, many got lucky that their card don't immediately blow up. This has something to do with yield and bin, but many will have better insight than me on it. Bottom line, overclock means lots of knowledge + some risk. Pushing voltage up blindly is a simple test of luck. Look at how many SB was fried this way. "Crank the voltage up to X, and change the multiplier to Y, and bump, 5Gb without heatsink!"
Qianglong
937
Radeon 6990 Thermal During IDLE:
Radeon 6990 Thermal During LOAD:
GTX 590 IDLE
GTX 590 LOAD
Courtesy of Hardforums!
Joseph F
3,522
^ 0_0 at both... why can't AMD and nVidia focus on power efficiency and not raw power? you'd think that they would due to the fact that PC games are going to be going nowhere for the next few years graphics-wise. (talking about console ports, of course.)
cusideabelincoln
3,274
41
Ok OK Ok thats one out of thousands.
You don't think other cards have done that?
Do you relize this topic is being amplified by 1000x by one guy who threw too many volts into one card? On top of that you have about 20 or so AMD marketers in these threads keeping these threads and this subject matter alive?
Badboy you are smarter then that.
I'm kinda glad I was banned, Talk to you in a few days when this crap is on the second page and the damage needed to be achieved is done.
You come back to make unsubstantiated accusations and then say Badboy is caught up in the conspiracy? It's also funny how you claim some users are "amplifying" the situation when you yourself are using hyperbole to the contrary.
PCboy
847
The fact that he calls techpowerup and hardware.fr as non-legitimate reviewers gave it all away. It's best to ignore his troll-provoking answers. I bet if Nvidia asked him to underclock his card to 200 mhz to make it faster, he'll believe it too.
Damascus
1,434
I keep seeing the same swedish video's reported at numerous foreign language sites. Ananads , Hocp, Toms , Canucks are all hearing about this, I'll wait to they write articles addressing this topic. Armchair engineers declaring this or that is not helping anything.
Heh and what then if they say the same thing? Are you going to tell us it's all good, like what you said after the GTX 550 Ti launch?
AnandThenMan
3,979
589
The 590 looks like a rushed out card to me, not enough time to properly test and refine the thermal and current protection systems. At this price point, I would expect some pretty robust circuitry, seems way too easy to kill these cards.
Ilias
54
I think Fermi does surprsingly well in the mid-middle/high end ranges
GTX 460, and 560 are some of the best cards for the dollar right now, and the GTX 580 was a slam dunk compared to the 480.
The 4xx series was/is plagued with compatibility problems throughout http://forums.nvidia.com/index.php?showtopic=187401
Personally, i had to buy and install a different motherboard in order to have the card working properly. What can i say man.
How Nvidia can skimp on components (I'm assuming) for a 700$ card is beyond me though...
To reduce manufacturing costs probably.
Will Robinson
1,408
The HD6990 hardly covers itself with glory...its too loud ,runs pretty warm and uses a lot of power.Maybe some people have a use for it but its a big clunker of a thing really.
I expected better from NVDA but it seems theirclunker is more of the same thing but a bit quieter.
Unless you have a big display and CrossfireX or SLI isn't for you, these two cards look a little dinosaury to me.:colbert:
tannat
111
Are you for real? Whether it’s 100% or 0% that fail overclocked, it’s still not the card’s fault.
The card is rated to operate at the volts and clocks it ships from the factory. Anyone that goes above those is taking a risk. If the card blows up as a result it’s not “faulty”, it’s the individual at fault for operating it incorrectly outside of its rated parameters.
The only way the card would be faulty is if it failed at factory voltages/clocks, but that doesn’t seem to be happening here.
Don’t confuse the overclocking hysteria on the internet with something that is mandatory and guaranteed from any piece of hardware, because it isn’t. Just because little Timmy can overclock something it doesn’t mean you can, should expect it to, or is “faulty” because it can’t.
Did you ask me if I were for real and bullshitting afterwards?
Sincerely why?
You 're taking an extreme stance that a lucky few manage to overclock their cards. And that it is a non issue that many cards blow if you try to overclock them.
All other cards in history where you rolled down the over clock when you hit the your limit instead of throwing it in the garbage can? They haven't existed?
Nvidia s not agree with you they told sweclockers that the card should be able to take the overclock ann explicitly asked them to proceed so with the second card.
You'r right in that it is a non issue for the seller since warranty is no more. But that's a very narrow view of it.
ZimZum
1,281
One of the links in Arkadrel's post is from someone that had 2 590s die. Both were at stock voltages and neither one was overclocked.
Feb 19, 2009
10,457
10
Have to say the 6990 is actually very good, robust PCB, temps are not overly high, mid 80s with good ambient. It's very loud if you leave the case open or near it, but from 1m away inside a case, all you hear is the airflow exhaust, not the fan itself which lessens the annoyance a great deal. I've just built a few rigs for friends with 6990s, in normal mode its actually not too bad. I wonder if sites like AT putting it at 65 dB is a realistic reflection in how its used (in a case, away from your ears). In operation, its only a tiny bit more "noisy" than a 5970 and its all airflow. While CF 6970 are faster, the 6990 is a nice package, about 100W less power use. Still doesn't beat a CF 6950 setup though.
Enthusiasts cards in generally should be pretty damn robust and have proper built in protection against tweaks that could kill the card. If over 1.05v is not safe, the card should not allow anything near that, period. $700 cards deserve to have higher standards.
PingviN
1,848
13
You must've been sleeping for the last 2½ years. Ever since RV770 showed up, power efficiency has been the name of the game for AMD.
tincart
630
This is entirely true. Only English-speaking people are allowed to pronounce upon exploding video cards. Every knows that speaking foreign languages seriously detracts from your ability to test video cards.
tincart
630
At my gaming resolution (1920 x 1200), AMD cards takes up 9 of the top 10 spots for performance/watt on Techpowerup's latest reviews. However, I think that with the level of performance we're seeing out of a GTX 580 or 6970, this whole dual-chip thing is getting a bit silly. Even good performance/watt gets you a loud, power-sucking beast like the 6990, or a card like the 590 that should apparently only be operated with a fire hose at the ready.
Great marketing products, I guess. They certainly have everyone talking.
wahdangun
1,007
148
Unless this is happening at stock voltages/clocks then it’s a non-issue. Overclocking operates hardware outside of its rated spec which it was technically never designed to do. Just because some people get lucky with some hardware it doesn’t mean it should be an expectation.
i dunno but take a look of this :
^^ This , i know already of 5 dead cards from my friends that died at stock voltages stock clock running heaven and Vantage benchmark , add 2 more testing on LN2 and 2 more on H2O = 9 cards already , how many dead 590s have not been reported ? this card cannot even handle 100% full load on GPU for long periods of time , yes it will blow up in smoke even at stock voltages and stock clocks. Nvidia should make a recall on this cards me thinks :/ , so many cards 590s have died and since has not been reported it looks thats just a few cards , the truth is , its going to happen soon or later , its like a time bomb , this card its a total failure and im sad i had high expectations on this card. Ill wait for the next 28mm cards to be release , as of right now 590 or 6990 are not apealing to me at all
linky
to me its look like hardware problem and check out new egg they pull out all GTX 590 from their website, its seems fishy to me
